Refrig Problems
Clean the sea water filter pump once a week. I tis not self priming. Take off the hose after the filter and force water into the lines. I put a check valve in the water line between the filter and the pump. Since the pump is not self priming this keeps the water from exiting the system during filter cleaning. Therefor priming is NOT required.I have 2 problems with my refrig., air leaks and freon leaks. When properly charged with freon and all air leaks eliminated I can get 13 – 15 deg. F in the freezer. The freon leaks in my case required a new compressor, under warranty. I am still evaluating the repair to be sure it finally works OK.There could be 2 sources of air leaks, the 3 doors not sealing properly and / or the inside plastic cabinet not sealed properly. Air leaks cause excessive frost build up and this causes a blockage of the fan opening that draws cold air into the refrig. compartment resulting in a warm refrig.. Use a mirror and a flashlight to view the inside top edges of the entire refrig.-freezer cabinet. In my 410 the front inside top of the plastic shell above the evaporator plate had “0” caulking to seal the cabinet. Forcing rope caulking into the gap solved that problem.For the 3 doors use a small paint brush to wet the top white plastic surfaces of the refrig. and freezer, where the black insulation touches down , one or two lengths at a time, with a light coating of alcohol. Allow the doors to close via the force of the latches, do NOT push the doors shut with excessive force. If required use a flashlight to see where the alcohol wets the black door insulation. Dry spots are air leaks. Remove the lid pistons to view the rear ends of both top doors when fully open.Where the insulation has dry spots pull open the black insulation from the back and insert the appropriate length of adhesive backed ¼” X 1/8” thick foam weather striping. Check again to be sure the repair allows the black insulation surface to now become wet. Finally I keep 3 or 4 1 gallon bottles of spring water, frozen, in the bottom of the freezer at all times. I have the 3 foot deep freezer and this helps reduce the volume that needs to be cooled.
