A couple of comments on reefing
Reefing is pretty much the same for most boats, but every boat has its own "wrinkles".For example, when reefing the H23 mainsail, the lowermost sail slug has to be moved from above the gate in the sail track to below it. You need THREE sail stops for the H23, one above the gate, one below the gate and a spare for when you drop one of the others while wrestling with the sail in the breeze.When reefing, I ease the mainsheet and vang, tension the topping lift, then drop the sail until I can hook the tack cringle over the ram's horn, including the sail stop juggle. Next, I tension the reefing line, which on my boat only controls the clew of the sail. With the halyard slack, the sail is so loose that the reefing line (it should be rigged to pull the clew down and aft as PaulK and Vern mentioned) tensions the new "foot" of the sail properly. Then I rehoist the sail, tension the halyard, ease the topping lift, sheet in and I'm gone.This procedure works on the stock H23 because all the sail controls are at the mast. If your boat is rigged differently, e.g., with halyards run back to the cockpit or single-line reefing, then you have to find a procedure that works for you. Practice reefing on nice days until you can do it without thinking. It will pay off when the weather turns bad. Good luck and safe sailing.PeterH23 "Raven"
