Reef marks
Dec 13, 2006
68
Beneteau 323 Milwaukee
I have a Beneteau 323. Original Neil Pryde sails. On starboard side of genoa were two reefing points. Had some sail repairs done and the sailmaker removed the black stripes that marked the two reefing points(roller furler). I cannot find out how far these two marked points were from the luff. Any 323 owners know? Thanks
Jun 21, 2004
3,113
Beneteau 343 Slidell, LA
Suggest you email Bob Pattinson, rep with Neil Pryde. He has a wealth of knowledge about Neil Pride sails for Beneteau.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Probably not what you want to hear, but ... the purpose of roller-furling is to give unlimited adjustments when furling, like the adjustments on a stove, rather than fixed stops. For my part, I just glance forward and see about two wrap, and call it good. Any rolling destroys the nice luff entry shape, so it's a compromise anyhow.
If you really want an indication of how much you have out, however, may I suggest you stretch the sail back on a windless day and make your own marks using draft stripe tape (for example, http://www.sailrite.com/Draft-Tape-Red-1), which you can do in multiple colors if you like. I suggest making marks only for a 10 and 20% reduction as more than that the shape of your genoa is completely shot. For example, if you have a 155% genoa, measure back and furl to 140 (10%) and 125 (20%).
Likes: justsomeguy
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
In my opinion, reef marks on a roller furling jib are not very useful - not because as Parsons says you can reef at any point, but because a well made roller furling and reefing jib should have foot and leech reinforcements sewn on at common reef points. In a 135%, say at 110% and 90%. If you don't have the reinforcements, it will quickly and prematurely stretch out the sail when you roll it up to reef. It's why there are heavy reinforcements at head, clew, and tack of any sail.
capta
Jun 4, 2009
5,072
I tout roller reefing as infinite reefing. Unless you actually have stress panels on your rf sails, it doesn't matter how far out or in you reef. It shouldn't be about marks anyway, but about how the boat sails when reefed.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
I guess the first question of mine would be, does your main have traditional reefing points? if it does then I can understand the marks on the jib referencing reef points. This would likely be done as a starting point to maintain the balance between the main and jib when the main is reefed, if the main is roller furling then I wouldn't see the need to mark the jib.
Likes: capta
Beneteau 323 Annapolis MD
I assume your question was regarding the OEM 116% JIB? I was going to go down to the boat (a couple hundred yards away) but it is rainy and thunder. Not to worry, I have my spare jib laying on the living room floor. Of course the foot was rolled up inside the sail, so undid it. The two marks are along the foot, maybe 6 inches long, pointed on the end. The two reef points are 18 and 36 inches from the tack corner of the sail.
Jun 21, 2004
3,113
Beneteau & Neil Pryde have an advisory that references the jib fair lead car position to the reef marks on the jib to maximize sail trim. If you mark the 3 positions on the fair lead track, when reefing the jib to one of the marks on the jib, you can do a quick & dirty adjustment to the corresponding car position. Then, fine tune the car as needed.
Not an absolute necessity but it does get you in the ball park quickly.
Dec 13, 2006
68
Thank you all. Great replies. Appreciate the advice and info. Love this website. Mike
