Kind of proud ....
When I singlehand, I have a tendency, as others have noted, to reef before I leave the dock, and shake it out later if things are too slow. So Saturday, for the first time in several years, I had to go through a couple of major sail reductions while I was out singlehanded. When I got home Saturday night, I fell asleep confident that at 59 I could still manage the boat safely and efficiently in a bit of wind by myself.
For purposes of generating discussion on singlehanded technique, here's how I reef my C27 tall rig tiller boat by myself:
1. Main halyard is pre-marked at the right place.
2. Set boat up on a balanced reach, somewhat forward of broad off, so she balances well into the waves.
3. Drop travellor and ease sheet so that pressure is off the main but not flogging really bad. Check balance.
4. Ease halyard to mark.
5. Go to mast, pull luff down to reefing gromet, secure (mine is a line, not a reefing hook, and I don't have to pull any sail slugs out of the track cause they are spaced such that the gromet comes down far enough).
6. Return to cockpit, pull travellor up enough to easily reach boom within safety of cockpit, secure leech gromet.
7. Tighten halyard and reset.
The whole thing takes a minute or two ... less time than to write about it, but I hadn't done it by myself in awhile. I was pleased that I was able to carry it off quickly and effectively. For me, I think the key is NOT the actual reefing procedure but understanding boat balance well enough to set a boat up on a sustainable course and be sure she'll stay there while you do a few things, like go to the mast.
I find reefing the main just a whole lot easier than changing out a headsail, which I also did on Saturday. Maybe at 59 I ought to finally break down and get single-line reefing, a furling headsail, and autopilot.
Tom
