And YOU. The antifreeze coolant cycles through your hot water heater and right out your galley and head water taps. If that loop fails, you have antifreeze contaminated hot waterHelps prevent accidental poisoning of pets
Thanks, thinwater, and others who replied. It's a bright, ruby red and there's no ATF on my boat, so that is ruled out! (My JS gear uses SAE 30 oil.) I hesitate to change it since it was supposedly fully serviced in the fall before it was launched for the sea trial; but who really knows. I may call the full-service yard who supposedly did it.Read the manual and see what it specs. There are at least 7 common colors, including rubine red. Unfortunately, color is only a hint as to chemistry and there is no industry standard (I'm on the ASTM committee). We made multiple green, yellow, and blue formulas with very different chemistries (for example, there is LD green, HD green, OAT green, and amine green).
And Gunni hit it on the head; there is no such thing as long-life marine AF. Too many salt leaks. For marine applications, most manufacturers recomend 1-2 years. tops. Just change it.
(I spent 20 years in the AF formulation business as a product development guy)
You likely meant "Drain". But it would be interesting if not.I would rain, flush and replace with a know coolant
Thank you. Can you possibly make a recommendation, both for topping off my red stuff, and for replacing when I flush it? (I have a refractometer so I can measure specific gravity/freezing point.)Those Westerbeke instructions were probably written at least 25 years ago, based on some of the language. For example, Prestone and Zerex both make multiple products, whereas in the past they made only one. Also, the modern water guidance (all manufacturers, ASTM standard) is distilled or DI water, similar to battery water (there is a spec).
Interesting. Basically no guidance. Just use a good AF.
Reguarding concentration, a 50/50 mixed (freeze point -34F) is required for proper corrosion protection. Climate is not considered a factor.
Both are equally biodegradeable and neither bioacumulates.
