Joe E.
Hello collective,I have a 2001 Hunter 320. Due to drought in Kansas and a job change it's been in a cradle for 2 years (isn't that sad?). I'm moving the boat to Seattle soon, and need some help!What are all the things I need to do to the boat to "convert" it from fresh water to salt water use? I'm sure there is more to it than adding a zinc. Are there any considerations regarding the through-hulls, engine cooling system or air conditioning system?I added an anti-biological agent and a fuel preservative to the diesel tank when I winterized 2 years ago. I'd guess there are about 8 gallons in the tank. Will this fuel be okay after so long sitting or will I need to drain the tank and fuel lines?What needs to be done to the engine after so long sitting? I suspect I need to replace the impeller on the water pump, change the oil and all filters...what else? Any other tips about the change from fresh water to salt water? Any other thoughts on "reactivating" a boat after 2 years of sitting?Thanks 1,000,000!Joe
