Recommended halyard length and line size for 1995 "C" cleated at the mast?
Sep 20, 2011
29
MacGregor 26 Lake Waccamaw, NC
Recently purchased '95, but main and jib halyards missing. Looking for suggestions on what to buy? The original MacGregor owner's instructions are a little different than the lengths recommended by MacGregor Owners web sit. Looking for the "voice of experience". Thanks
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Our Rigging Calculator tends to run a few feet longer than factory specs, because the length is calculated back to the cockpit. If you want to go with your specs, our Rigging Builder allows you to pretty much select whatever you'd like, Samson XLS is recommended and that is the default:
https://shop.macgregorowners.com/detail-rigging.php
Jul 29, 2010
1,392
Macgregor 76 V-25 #928 Lake Mead, Nevada
Measure deck to halyard block X 2 and add a few feet for tail. :biggrin:
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
Go to the hardware store and get 100 feet of 1/4 inch nylon braid and run each line the way you want and then measure it. being sure to remember that you will have to cleat it off when the sail is down. You will always find uses for the 1/4 line and not feel bad about cutting off small portions for whatever, just heat the ends ti keep it from fraying.
