Recommended A/C and Heat brand
rlamb
May 21, 2013
66
Hunter 46 Alameda
I have a Hunter 466 and am planning on installing a Reverse Cycle Air and Heat unit to the main cabin/forward cabin. I see units from both Marine Aire and Webasto and wondered if anyone had any recommendations on noice and reliability?
Rgds,
Roger
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Marine Air
I am pretty sure I have Marine Air factory installed in my 2007 H-36 and have used the AC here in Florida with out a problem and have even used the reverse hear 1 or 2 times.
I would look for a unit that uses a stainless or maybe plastic bottom pan and that is the only thing that I wish I had in my unit,the bottom pan seems to create rust and the compressor on my unit is all rusted.
I think I have heard that they now use plastic or stainless to stop rust and make sure it has extra drain holes open.
And if in hot area you will need 2 big units for your size boat.
Nick
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Re: Marine Air
check out the ocean breeze unites they are good ones but not reverse cycle they have an electric heating element.......
regards
woody
Dec 19, 2006
5,836
Contact Hunter
I would contact Hunter and ask for any info they have that they have
for installing your unit.
I am pretty sure they will send you the wiring and what they did for installing the duct work and panel breakers and all hooked to shore power,you will need 2 new shore power plug in for each AC unit.
And Marine Air now uses stainless bottom pan and if and when I need to replace mine I would go with Marine Air.
Nick
Oct 17, 2011
2,809
Ericson 29 Southport..
This 82 footer that we've been getting ready to go has 19 A.C.'s in it at the best count.
Now THERE'S a nightmare.
(Amongst other things)..
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
Flag Ship Marine
I've used a Flag Ship Marine unit for 10 years with little trouble. Ours has electric heat. Sure is nice when you are on the hard. Nice that a compressor and water pump aren't needed for heat. The frame work and pan on this unit is stainless. http://flagshipmarine.com/
Gunni
Mar 16, 2010
5,937
Serious Question: Why would anyone buy a high-dollar item like a marine heat pump, that typically requires install and warranty support from someone named "White Depot" on E-bay? The pricing seems no better than that being offered by any number of factory dealers, and the forum operates like some kind of street bazaar in the third world - no one in charge of quality assurance. I don't get it.
