I am finally getting around to rebuilding the fixed portlights on my H34. The boat is an '83 so I have the aluminum frame version. Got everything removed yesterday and cleaned up so I can see what I've got to work with.
The frame is basically a Z shape that has a notch to receive the plastic glazing retainers the factory used, I am amazed they designed it that way from the factory. I am planning to use 1/2" acrylic that will be just shy of flush with the outside and Dow 795 to seal it up.
However, to set the acrylic in the frame I am wondering if I should use butyl tape. The factory used neoprene glazing tape (see photo) but seems like I read somewhere butyl tape the best approach. Any thoughts?
