Rebuild idler?
298
'79 Hunter 33' HUN33190M79L Olympia
As you can hopefully see from these pics, the plate on my Edson steering idler, under the base of the pedestal, corroded apart. The bronze wheels are in good shape. I thought I might get a plate at the scrapyard and fashion a new one with the old wheels instead of springing the $300 for a new one.
Has anyone else done this? Bad idea?
Ignore the last two pictures, repeat of the first one.
Ross
Jun 15, 2004
14,693
poor choice of material for the application. Correct the deficits and rebuild it if you have the skills.
Nov 6, 2006
10,253
Stainless if ya don't want it to corrode, but the original steel lasted 34 years.. That one has swiveling idlers, but you don't have to duplicate that as long as you are precise with getting the angles and positions of the idlers set for a fair lead to the rudder shaft pulley. Fab it of steel and paint it with coal tar epoxy .. it'll be there a while !
capta
Jun 4, 2009
5,102
Looking at your pics, I had to go into the engine room to check, and yes, my unit is solid bronze. Yours seems to be some on the cheap steel fabrication. I would not recommend repeating that mistake; bite the bullet and go for the proper unit from Edson in bronze.
Jun 3, 2004
298
Capta, is yours original or refit? Apparently the replacement units from Edson are largely anodized aluminum:
http://www.edsonmarine.com/marinestore/index.php?main_page=index&cPath=244
I have a great scrapyard nearby so could find a sheet of most any metal. I was also thinking of using plastic or fiberglass. - I can probably make a pattern from the old one so getting the angles right shouldn't be an issue...
Gunni
Mar 16, 2010
5,937
You can get them with bronze base plates, but anodized aluminum should be fine for a 33ft. boat.
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
1/4" alum plate will work, double up if you want. Its easy to work with and cheap, and plenty strong. ...Red
Oct 17, 2011
2,809
Ericson 29 Southport..
Plastic or fiberglass would not last one minute. Tremendous loads on those sheaves. Mine are Edsom bronze as well, but last I looked, they ARE now aluminum. Fairly pitiful considering Edsons pricing. Yeah, if you can save the sheaves, I can see a man building one in a GOOD fab shop, but your jigs would need to be right..
