G
ghadrill
I am planning to rebed stanchions with no direct access below deck due to a glued head liner. Several questions1) What is the best method to access thru the headliner and then cover up the hole? I have not found any access covers other than the Beckson deck covers which appear to be overkill for the task. Any other simpler plates avialable for interior work?2) What do I do if I run into the situation where the deck bolts are screwed into a tapped plate epoxied in place in the deck? Someone mentioned on my model this is likely. ie no bolts with nuts -simply a tapped plate. 3) Preferences re bedding compound based on the approach to the task? Thanks all.
