no kidding
I've tried filling the hole with epoxy, then drilling it out and re-anchoring the snap with a drywall anchor.The only problem is that usually there's nothing behind/under the deck to keep the wet epoxy in place. If you can get something crammed into the hole to catch the falling goop and hold it in place, then you're on your way to success.I've also tried pushing in some wet epoxy, then just dropping the snap into the wet epoxy and let it harden with the snap buried in it. It sounds dumb (and I won't do it again) but it actually worked.Paulsv Escape Artisth336
