I've embarked on a 2 year project. I recently purchased an old Plastic classic, a 1962 Shock 25, hull #63. This boat was originally in San Diego, as best I can tell and spent the better part of its life in salt water. I found it after it sat outside in Wyoming for 5 years.
My plan is to restore it to some sort of sailing condition and use it as my race boat here in Colorado. All of the hardware is corroded beyond repair as well as most of the rigging. I'm just about done stripping everything off the boat so I can dig into the sanding and prepping for painting next summer.
Now for today's questions. I pulled the rub rail off to expose the hull to deck joint. As I work to clean that up, I've found that most of the rivets along this joint are heavily corroded. The caulking in the joint appears to be reasonably solid and intact.
Should I (sorry I don't have any pictures):
1. Replace all of the rivets since the existing ones are in bad shape
2. Dig out the existing caulk (who knows what it was back in 1962) and replace.
I don't mind doing the work but, don't want to do extra if its not really needed. This will be a race boat not a showboat and it will be on inland lakes not open ocean, so as longs as it doesn't impact the general integrity of the boat I'm OK.
I'm looking for opinions and comments, all are welcome.
Thanks for taking the time to read and/or comment,
Victor
Shock 25
Victor
Shock 25
