Rebedding bow pulpit on Catalina 310
Apr 6, 2013
166
Catalina 310 Annapolis
I recently purchased a 2002 Catalina 310. During the survey, the moisture meter read "wet" around two of the stanchions for the bow pulpit. I want to take the whole pulpit off and rebed it but can't figure out how to reach the bolts on each of the pulpit stanchions. Has anyone ever done this and, if so, how did you get at the bolts? There is a PDF on this board showing how someone rebedded their lifeline stanchions by removing wood trim in the cabin and then cutting away the fiberglass. That is not something I want to try. Has anyone found a less invasive way to get at the bolts?
7,725
Alden 50 Sarasota, Florida
Presuming you have to remove the rotten core material, the bolts should be accessible once you cut open the deck.
Apr 6, 2013
166
I am hoping it is only a small patch of wet core that I can use the drill and nail at a right angle method to take out the wet core then fill with epoxy and redrill the holes. But I will need to figure out how to access the nuts to remove the bolts to assess the problem.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
The forward two supports have aluminum plates embedded in the hull. There are no nuts. Just unscrew. I find the #3 Phillips bits for rachets to work best.
The back two are another story. Each base has three machine screws that are backed with fender washers, lock washers and nuts. After you remove the wooden panel at the head of the bed you can crawl in and see two of the nuts by looking straight up at the bulkhead. The stern most bolt and nut is accessed under the teak trim piece in the berth. It was by far the worst one on the boat to reach. My wife had to do it because my hands were too big.
I hope you are counter sinking the holes and using Bed-It Butyl Tape so you never have to do it again.
Good luck
Likes: Alansails
May 6, 2019
48
Catalina 310 0063 Nepean Sailing Club, Ottawa
Curious how things turned out. We had a higher reading on one of our forward stanchions when we purchased our 2001 boat. When I asked Catalina about it they said likelihood was that the moisture meter was reacting to the plate that was embedded in the deck and not moisture. What did you find?
Apr 6, 2013
166
I decided life was too short to do the rebedding myself so I hired someone more skilled than I to do the work. There was no doubt from the moisture readings that I had an issue with water getting in through a deck penetration. Here is what the contractor said about the job. It was difficult and I am glad I didn't try it myself. When I am finally retired and have the time, I will tackle future projects like this myself.
"the bow rail fasteners were tapped into a plate embedded in the deck.
Several of the fasteners sheared off when being removed and had to be carefully drilled out and retapped to receive new"
May 6, 2019
48
Glad it worked out. Im a big believer in letting the experts do the tough stuff. Enjoy your boat!
Likes: Alansails
