reasons for not getting an 8 hp outboard?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
txtowman: I own and have used both 4 and 2 stroke motors for many years and have never noticed any difference in running 10% ethanol in them. They both will gum up their carbs if left sitting without running out the gas. Otherwise, they perform equally lousy on it! Chief
Oct 26, 2005
2,057
- - Satellite Beach, FL.
I started with an 8 pitch prop on my Tohatsu 4 stroke 6hp and while it moved the boat well and economically (hull speed at half throttle) it was no good for slow speed maneuvering so I went to a 6 inch pitch prop which is great in slow, stopping and backing but causes the motor to run louder at speed because of higher rpms.
This is an issue for my boat where the OB is in a notch in the transom. For me a 7 inch pitch may be the best solution.
Nov 26, 2012
2,315
merlin: Why not use a 4 blade? Thats what the 25", 2013 Tohatsu 9.8hp comes with for sailboats. Chief
Oct 26, 2005
2,057
I like that but when I looked at both tohasu parts and defender they only show the 4 blade for the 8 and 9.8 motors. The 6 is the same as the 4 and 5.
Guess I could contact tohatsu and find out from them if the hub is the same. the 3 blade is 8.375" and the 4 blade is 8.7" diameter so the clearance should be ok.
Thanks Chief!
Nov 26, 2012
2,315
Merlin: try deepblueyachtsupply.com, ph#18004546960. Looks like you can provide info and they will cross reference their prop specs to see what will match. Let us know if you find one. Chief
KJH
Jan 28, 2009
73
Catalina 1983 22 Waukegan Harbor
Amen!!!
Where do you get ethenol free fuel?
I would also gladly pay the price to get ethanol-free gas. We are located on Lake Michigan, just south of the Wisconsin/Illinois border, and have yet to find a gas station or fuel dock in the area that sells non-ethanol gas.
Nov 28, 2012
148
Catalina 22 #442 Somerset, Ma
One would think the people could get this garbage over turned and out of our vehicles. Ethanol is a sick joke that helps no one but the pockets of very few
Erik V
Mar 14, 2012
104
Macgregor 25 Stony Point NY
Check out your local airport by 5gal of 100LL no alcohol with a very low led content. I use it in a 87 Honda 7.5 works fine.
Erik
KJH
Jan 28, 2009
73
We sail on Lake Michigan between Illinois/Wisconsin border. I would GLADLY bear the extra expense of purchasing ethanol-free fuel, if I could find it.
In lieu of ethanol-free availability, we keep as little fuel in the tank as needed. We always add marine stabilizer as well as purchase and keep a fresh gallon of gas(usually Shell) aboard just in case. At the end of the day, if not used, the fresh gas goes into my car's gas tank for the ride home. This season I plan to make it a point to disconnect the gas line and run out any leftover fuel from the carb when I know we will not be back for a few days.
Oct 26, 2005
2,057
Did you check the site Dixiedawg posted?
Bunch of stations in WI: http://pure-gas.org/index.jsp?stateprov=WI
Nov 18, 2012
183
Catalina 77 - 22 / 75 - 30 Lake Arthur, LA
I think you are in the wrong colored state. Come to Louisiana, can't throw a rock without hitting a real gas station. We'll that's overstating it, but you don't have to look that hard.
Oct 26, 2005
2,057
Thank you, so much. A very nice reference, unfortunately, nothing near SE border of IL/WI.:redface:
bummer!
well, stop by- there's an eth free station just a few blocks down the road.
you can stop at Naharts and then swing by. It was 84 here today.
Nov 28, 2012
148
I found two within 65 miles. gonna have to fill some cans next spring
On a side not i got 2 inches of snow yesterday. Ehhhhhh ,winter stinks, but at the same time it gives me free time to do projects
