I have been working on speeding up trailer to sailing. I am trying to get it to under 30 minutes(by myself). One of the big things that slowed me was the rear support for the mast.
I made this rear support out of PVC. When the cross brace is not in place the mast is tied down to the rear railing(trailering) or if the mast is up the supports act as fishing pole holders.
I got a longer jib halyard that will run through the pulley system I have set up to raise the mast. This will save me time. Now I will slide the mast back, put in the mast bolt, tie the mast raising system in 3 places(bow and lifeline stays), attach the jib halyard to the mast raising system and run the other end of the jib halyard though the pulley and pull up the mast. Then attach the forstay and tighten. Pull the main out which is already on the boom and attach.
The other thing that slows me down is moving the rudder from the cabin to the back of the boat. It is heavy and awkward. I don't have a good answer for this one. The best I have is putting down thick towels so I can slide it over the cabin hatch and then slide it over the rear of the cockpit.
Finally I take the outboard out of the Suburban and hang it on the mount.
Then launch and sail.
I am open to any suggestions for a faster rig.
