For this to even have the potential of working, you would need to electrically connect the pennies to whatever you are trying to protect, the strut or the prop shaft. I hate to think of the vibrations you'll get with a bag of pennies strapped to the shaft.Since the U.S. 1 cent coin is made of zinc sandwiched between copper I'm going to try using a bag of pennies as a sacrificial zinc anode on my sailboat. If you have tried this how did it work for you ?![]()
I'm not sure I'd reject this so quickly.Jim
This is a joke, right? If not, I would really appreciate pictures I can show around the marina
1. sizeI'm not sure I'd reject this so quickly.
If you took ,say, 50 (post 1982) zinc pennies... put them in a jig in a drill press and drilled a small hole thru the entire "roll"... repeated that with 3 or 4 "rolls" ... then ran a bare copper wire thru the holes in all the pennies ... how would that be any different than buying a made up zinc fish???
Maybe a little trouble, and you'd need a drill press to drill all the pennies quickly, but.... :dance:
Are you CRAZY? Do you know how much pennies cost these daysSince the U.S. 1 cent coin is made of zinc sandwiched between copper I'm going to try using a bag of pennies as a sacrificial zinc anode on my sailboat.
1. size .... 200 pennys w/ copper wire thru them would be rather smaller than typical zinc fish
2. waste of time ... perhaps, & granted it's would be "mickey mouse"
3. copper won't erode exposing the zinc ... zinc would be exposed in the central hole of each penny, providing significant total zinc surface area which would increase as the zinc underwent electrolysis inside the copper plating of each penny.
4. it isn't pure zinc ... 1982–present* 97.5% zinc core, 2.5% copper plating
5. never achieve a good electrical bond ... why not ????
6. it's a joke ... probably so, but for $2.00 worth of penny s, a piece of wire, and 10 minutes time ( w/ a drill press) ... it sure beats $42.99 for a zinc fish at WM
OK, it probably would be a wast of time...but, why shouldn't a few hundred (copper clad, zinc) pennys, (w/ ~ 3/16" holes drilled in the center of each), strung along (within the loop of) a piece of copper wire which suspends them in the water, not function as a sacrificial zinc anode?
