Here's the deal
Glenn,When you say your knotmeter does not read while anchored in a "strong tide", are you saying there is a definite flow of water past the boat?Is the boat aligning downstream of the mooring bouy in this tide?Can you see water streaming past the boat as if you were motoring or sailing?The "transducer" is the whole unit in which the "impeller" is mounted. The impeller travels at a speed proportional to the speed of the water passing it. The internal electronics of the transducer measure the speed of the impeller and transmit it to the display computer.Now, as far as motoring with or against a tide or current and the speed doesn't change, that is normal. As a flight instructor, I have found this whole concept is difficult to understand for a lot of folks. The concept applies to airplanes as well as boats. Let me see if I can explain...Think of the water not relative to stationary land, but as a giant moving mass. Now put a boat in that mass which is not motoring or sailing or anchored. How fast is the boat moving? Through the water its sitting in, zero.Past the sea bottom, however fast the mass of water is moving.What does the knotmeter say?Zero. The knotmeter reads the speed through the water.What does the GPS say?However fast the mass of water is moving. The GPS reads the speed of its receiver across the face of the earth.Lets say you are in a river with a 3 knot current in a boat motoring at 5 knots:Going upstream (against the current), the knotmeter will say 5. All it cares about is the speed of the boat relative to the mass of water its in.The GPS will say 2 knots. All it cares about is the speed of the receiver relative to the face of the earth. 5 knots within the mass of water, MINUS the 3 knots the mass of water is moving equals 2 knots across the bottom.Going downstream (with the current), the knotmeter will read 5. All it cares about is the speed of the boat relative to the mass of water its in.The GPS will read 8 knots. All it cares about is the speed of the receiver relative to the face of the earth. 5 knots within the mass of the water PLUS the 3 knots the mass of water is moving equals 8 knots.Hope that clears it up!Tim
