I have an old old 2QM20 that I am rebuilding. The transmission is very rare. Only 30 made by Yanmar. Then they switched to Hurth transmission.
So the output shaft was pitted and corroded. I put it in the lathe and turned it down until I got a smooth surface. The seal was a 50mmX30mm. I can buy a 50mmX28mm. The shaft is now 29.5 mm. I need to turn it down a bit more.
While I was turning it I noticed that the area where the seal contacted was hardened. It is only case hardened so I may have cut away most of the hard area. Does this have to be a hardened surface? Or can I get it to size polish it up and start assembling?
