Re-running wires to mast
120
Hunter Legend 37.5 Isla Saboga, Panama
I've just replaced the starboard chainplate bulkhead in my new '87 C-27. (And I did a mighty fine job, if I do say so myself!) The Git-rot treatment I tried first to try and save the original bulkhead ended up looking like sh#t with all the little holes I had to drill. On the positive side, it did strengthen the bulkhead enough so that I was able to get it out in one piece and use it as the template for the new bulkhead. Anyway, in order to remove the bulkhead, I had to first remove the compression post, which would not come out until I undid the wiring connection at the mast step and pulled the wires back through the post into the bilge. Then the post came out without a problem. I used a couple of 5' screw jacks to raise the cabin top up enough to provide clearance. Now that I've got it all back together, I need to get the wires back up the compression post from the bilge to the mast step. I've discovered that pushing a wire is a lot harder than pulling one! Anybody have any neat tricks for getting this done? In case I need to remove the compression post again, I've decided not to screw the bulkhead back in place yet. I'll wait until I've got the wires back in first.
Apr 6, 2007
120
joe friedman
send in the messenger
make a snake out of a flexible solid wire and either push it down from the top or shove up from the bottom. use this as a messenger and then attach the wires by wrapping them around the messenger with electrician's tape. pull/push them through depending on which way you arrived. try using a heavy gauge wire scavenged from a length of household AC cable - 12- or 10-gauge might do the trick.
joe friedman
Apr 6, 2007
120
Success!
Joe, thanks for the tip. I got the wires fished back up the compression post, but it was definitely a two-person job. My wife down in the bilge pushing the snake wire up, and me up on the deck with a small wire bent into a tiny hook to stick down the hole and guide the wire up and out. Now that I've done it, it was easy!
Apr 6, 2007
120
Success!
