Replating Winches
Hi Melody, Trying to find someone for a small plating job will make it quite expensive. However, another option is to have them powdercoated. This is where a shop electrostatically applies a colored powder and then bakes the object causing the material to bond with the metal. I had a friend's done a couple of years ago in gunmetal gray and they still look perfect. He races, and his winches take a tremendous beating. The cost was $97.00 for two Barient 20's. Compare that to the $250.00 to $300.00 estimates for re-plating. Hope this helps.Cheers,Bob
