Re: hello engine replacement , install of M16 kubota universal advic
Tim
Jun 29, 2004
57
Oday 30 Port Jefferson, NY
hello again, I ut out the request on info for this M16 installation. Is anyone out there available with phone and email to talk to asap on this. I need likely another 1" shaft and cutlass bearing, for new shaft install of the kubota here, . Or...does someone have for sale or know where to more affordably than not source a 25 mm shaft such to fit in the existing bearing race and housing that now accomodates the 25 mm combishaft? I am trying to adapt the shaft already there, the combi shaft without using it , with prop pinned in place for the right pitch. Has anyone tried to adapt this old shaft in a conversion.Boat is on trailer to easy work on here. Is there a mechanic to talk to out there on all this? Steve, what is your email to talk directly with you since yousound like the pro on much of this. We do not have alot of money to through at this . TIm B ecoearthyacht@...
[Non-text portions of this message have been removed]
