Thanks. Sounds good...
I think I'll try it. But we just got our boat back in the water after a prolonged, self-administered bottom + keel job, so I do believe I'd like to sail for a month or so before going back to work. (I never thought I'd put so many sweat-drenched hours + weekends into something you do for fun...)Anyway, here's another interesting bedding/caulk related point: I rebedded one stantion which was loose + a bit bent, during the recent refit. I masked the deck and ended up using 5200, making a nice rectangular pad, which I put under compression only after it had cured for a week. At which point, it occurred to me that there was a hole in the bottom plate where the stantion tube was supposed to drain if + when water got in around the lifeline up at the top of the tube. And I had effectively caulked up the hole. This doesn't seem like a good idea. Maybe I should have just caulked a little ring around each of the 4 screws that hold the bottom plate to the deck. I don't think the other 3 stantions have caulk under 100% of the bottom plate.I tried to fix this problem by running a small drill bit horizontally through the caulk pad, and into the place where the tube hole comes out, to provide some drainage. Has anyone else noticed this problem?Thanks again,Jay
