Re: [AlbinVega] Stuffing box
Oct 30, 2019
96
Sebastion, what you describe is a "stuffing box" or shaft seal. Sounds like
it is time to repack it. Not hard to do. We have the same kind on our boat.
Your local chandlery has flax packing. I like the teflon impregnated kind.
It comes in various sizes, on Lyric we use 3/16". It comes in a roll and to
use it you will unroll a piece long enough to go around the shaft. Ideally
you should remove all of the old packing. If the boat is out of the water
this is easy but if you are in the water you will take quite a bit into the
bilge before you're done. Make sure your pumps are working first! Okay now
here is the process. Imagine the packing is a series of 4 or 5 washers on
the shaft. You will cut pieces just long enough to go around the shaft and
you are going to need 4 or 5 of these pieces. Make the cuts on a diagonal.
Next part is separating the two halves of the stuffing box. Put a wrench on
that aft hex and hold it still. Put another wrench on the forward one and
loosen it. Obviously you are going to need big wrenches for this so you
might as well go to the chandlery and buy a couple of packing wrenches. West
Marine sells one SKU 290280 for $8.99 so this isn't going to cost a fortune.
They also sell an extracter for removing the old stuffing, skip on this, you
don't need it. Quick fix is to seperate the two halves. As you do so you
will notice that after the male threads of the forward half clear the female
threads af the aft half that there is a flange extending into the aft half.
(This is an integral part of the forward half.) Slide the male half forward
out of the aft part. Put a piece of the flax around the shaft between the
two halves and push it into the aft half. Slide the forward half back and
use it to seat the flax. Tighten it up and your problem goes away.
To do it right you need to remove all of the packing. I just use a piece of
coat hanger wire which I flatten on one end and put a very small 90 degree
bend in. After the halves are seperated dig out the old rings of packing and
put new ones on one at a time and push them into the aft half until seated.
Stagger them so the diagonal cuts of each piece are well seperated from next
piece. Best done out of the water but you can do it in the water. You
mentioned that you have a rubber tube with hose clamps on it. This is one of
the hoses that needs double clamps and while you are at it get new clamps,
no telling how long the old ones have been on it. One last thing. get a
tapered wooden plug ant attach it nearby so if you loose the shaft you can
get a plug into it. All of your through hulls should have these plugs
attached to them, Not only is it a good idea, it impresses the hell out of
surveyors! West Marine sells these also, I think Defender and Boat U.S. also
carry them.
For folks who haul out at the end of the season. When you launch, do so with
the cockpit sole removed and watch for water entry at the seal. You could
put an extra tank under that sole. If you elect to do so make sure it
doesn't cover the seal. You could loose the boat.
On salt water pumps and through hulls.
We glassed in the one for the head and Tee off of the one under the
starboard settee. There is a one way valve forward (check valve) to keep
from pulling salt water in to the sink from the head but it probably is
overkill. Our boats sit in a soup made from numerous organisms and waste
from the animals that swim in it. Out of the marina it is quite dilute. In
the marina there is little cause to use the salt water pump.
The intake for the engine also has a Tee in it. If we are sinking I can
close the through hull and open another valve on the T that is connected to
a hose and strainer in the bilge. The engine has now become an auxillary
pump which is also recharging the batteries that are powering the 500 gallon
duty pump and the 2000 gallon emergency pump. While on the subject think
about hard wiring the pumps directly to the batteries. In case of a fire in
your electrical box you won't lose the pumps.
We also have a washdown pump. I've read that these should be mounted forward
so you can wash your chain and anchor easily. We mounted ours in the aft end
of the cockpit and take a hose forward as needed. It shares the engine
intake. We lost a Hallberg Rasey to a fire which we could have fought from
the cockpit if we had a means of pumping water.
Now we do. Once again it has a Tee and can also be used to pump the bilge.
The manual pumps that came on the Vega went from horrible to inadeaquate.
Think about replacing it also.Carry a bucket too. It has been said that the
most effective water removal system on a boat is a scared crew with a
bucket! Walt S/V Lyric #120
Hi Mort. I just went back to the in box and see that you are responding to
Sebastian also. Did you get the trailer? I replyed to your message out side
of the group but have not heard back from you. Please contact me at
pelagicasd@....
Oct 31, 2019
562
Hi Dan:
I guess you're in trouble. From what you write- you need new seals! And
most likely
new bushings. The Albin Catalog Nrs for these parts are:
Bushing.......................... 49192
Seal rings...................(2) 52802-156
Stuffing box complete .....49193 (75908)
These parts used to be available here in Miami, if you like, I can find
out if they still
have them.
About replacing? You need to have the boat out of the water. It's not
too big a job,
I've done it several times, but if I was you, I would do it soon.
Wilhelm, V-257
Dan wrote:
Nov 8, 2001
1,818
Hi Dan
You may need seals and white metal bearings. It may be that teh control
tube is
worn at that particular point so if you leave the boat in reverse and see if
the water still comes out. Worst case is combi and control tube.
Regards
Steve Birch
At 23:32 19/05/03 +0000, you wrote:
Apr 20, 2003
2
Hi all: Dan here.
Where Can I obtain the parts for the bushing and seals, it sounds
like the least i will need. How are thess installed?
Thank you
Oct 31, 2019
562
Hi Dan;
to put the seals and bushing into the stuffing box is easy- to take out
the sleeve
and shaft is a job by itself!
Like I wrote in my last e-mail, I'll call the marine-shop here and ask
if they still
have parts. I'll let you know.
For now I recommend you press grease into the stuffing box (until the
grease comes
out around the seal).
At the same time, check out the alignment of the (shaft) and sleeve.
Take a pencil or
some other pointed stick and while the engine is running, hold the
pencil as close as
possible next to the stuffing box against the sleeve. It there is any
sideways movement
of the sleeve, you need to adjust the seating of the engine. Many times
a miss-aligned
shaft is the cause of waer and tear of seals (not to mention the bearing
inside the combi
drive).
Wilhelm, V-257
Dan wrote:
Nov 8, 2001
1,818
Hi Dan
We sell a complete kit for £38 or equivalent in US Dollars. It come complete
with full instructions (step by step) and diarams. Easy to follow and even
Diana, our secretary< changed her combi. It consists of all you need to
rebuild
the combi and stuffing box. Pointless not to do the lot whilst the combi is
out
as that ids the hard bit.
Payment made out to Diana Webb (she has a US Dollar account) and send to me
at:
Steve Birch
8 Cockshot Road
Malvern
WORCS WR14 2TT
U.K.
Regards
Steve Birch Vega "Southern Comfort" V1703
At 10:25 20/05/03 +0000, you wrote:
Aug 9, 2000
55
i went 2 seasons using the boat every weekend and it would leak like a stuck
pig only after the engine was run.. so after running i would fill with
grease... then it was good until the next time she was run... the cutlass
bearing was shot when i got the boat and had been glassed into the hull.. had
to pull replace cutlass bearing and then replace seals. did that some two
years after purchase.... so if it don't leak after it is greased without the
engine running you can go for sometime to delay the eventual...
dan
Aug 28, 2003
5
Hi,
I'm new to this group and sail Vega 1651 "Svegala" out of Dublin - Ireland that is.
Can someone tell me what does a stuffing box do, how does it do it and what maintenance is required.
Nov 8, 2001
1,818
Hi
The stuffing box is the seal between the water and the inside integrity of the
boat. It allows the shaft to turn whilst preventing the outside water to pour
into the boat.
The usual arrange ment of stuffing box for the Vega is an Oil or Grease Bath
bronze holder with two white metal bearings and two lip seals. The maintenance
consists of keeping the oil or grease topped up.
I would suggest you join the VAGB as most Irish Vega owners are members. You
will receive Newsletters, Technical Notes Bo0oklet (Tells you about the
stuffing box/sterngland) and access to a host of spares and technical
expertise
(me!!). If you would like to join then drop me an email and I will send an
application form. We have members from Australia to Israel to India!! There
are
quite a few Vegas in Ireland including three at Kilmore Quay in SE Ireland.
Kind Regards
Steve Birch Vega "Southern Comfort"" V1703
At 00:14 12/06/03 +0100, you wrote:
Oct 30, 2019
77
Hi Steve and anyone else who knows,
2 Follow up stuffing box questions;
1) Earlier I posted a question about a device that appears to be an
automatic oiler for the stuffing box. You recommended filling it
with outboard engine oil.
I did that, and after two weekends of sailing (only about 2 hours of
motoring in total) about 3/4 of a quart were gone. Is that normal?
Where is the oil going, into the bilge or into the cheasapeake?
Or, is it possible that the stuffing box holds that much and just
happend to be completely dry?2) I was reading Nigel Calders book on boat maintenance and he talks
about replacing the flax packing periodically and mentioned a new
teflon product. This sounds different from the typical Albin set-up
you described. Do I need to worry about replacing the packing?
If so is this something a novice could do i the water without
flooding the boat? He mentions a tool with a spring on the end that
hlps remove the old packing. Do you sell those, and do you sell
this packing material?
Oct 30, 2019
8
Ron
I think our Vega's must be the same age. Not only is Annabel
producing the same smoke she was also drinking the oil in the
stuffing box. There are seals on the prop that require replacing - As
ever Steve B can send you a set (locking rings gasgets etc) which
saves getting half the job done and realising your missing a crucial
bit. Ask for two sets of rubber gasget and load the spares on the
prop (you'll see what I mean from the instructions that come with the
kit) so that when the next set fail you can just cut away the old
ones and push the new one up without having to dismantle the entire
prop mechanism again.
It's not that difficult but a bit fiddly and be warned the
instructions require you hit the end of the propeller hard with a
large sledge hammer - a traumatic experience!
It took two of us two days for the whole job but I am an incompetent
so a weekend out of the water should do it. Before I did the work in
March I was going through a pint of oil a day but have not had to add
oil since.
Good luck
David
Annabel v1745
ps to Steve B - In my defence I took 2 novice crew round the island
who found the tacking a bit of struggle but I am pleased to report
Annabel breezed past many larger racier beasts during the day. But
then I beleive you are well used to being passed by Annabel (nee
Vindrosen)!!
Regards
d
Oct 31, 2019
3
Dear Bue Jensen,
No offense, but could you please sign your emails. I think I heared from
you lately, and your first name was Aksel, I think.
It is nice to know the names of people who you are communicating with.
I only mean this in a positive way.
Best wishes
Erik B. Simonsen
Chairman of the Danish Vega Association.At 17:29 23-06-03 +0200, you wrote:
Nov 8, 2001
1,818
Hi Ron
1. If you are losing taht much oil then the sterngland is either worn or the sealing rings are no good. The oil canbe going into the bilges if the forward most lip seal has worn or into the sea if the aft seal has gone. The problem may also be caused by a worn control tube. The Combi kit also contains complete new bearings and seals for the sterngland (£38). The control tube is also available (£105). Best to change both but you can check the tube for wear once it is removed.
2. The stuffing box (sterngland) mentioned by Nigel Calder is completely different to the standard Vega type. There is no packing to worry about.
Hope this helps.
Regards
Steve Birch
Apr 28, 2000
691
Yes, well my entire name is Aksel Bue Worm Jensen if you must know :)
Kind regards, best wishes, happy sailing and all that
Mar 20, 2002
33
I posted a stuffing box question a while ago, and was told that it was a fairly involved job on dry land. I passed for the time being. It was mentioned that the screw fitting inboard of the hose section should be loosened and grease applied twice a year. Now I think some of you are talking about putting oil in there. Is this the same fitting and should it be a part of regular maintenance? Do we use grease or oil? I just went and bought waterproof grease for it, and there is grease on many bits of my engine, also it appears to be oozing out where the prop shaft enters the actual engine. Do I put more in there? and how?
I'm starting to get more confused.
Help or at least clarification would be greatly appreciated.
Regards,
Christine
Nov 8, 2001
1,818
Hi Christine
The standard Vega stuffing box (sterngland) can use either grease or oil. If
you use oil then you need a mod to have a slight positive pressure resevoir
abouve the sterngland by about a foot. This just takes away the need to keep
pumping grease in as it is easier to fill the resevoir with oil once a season.
The grease coming out of the back of the combi is different altogether.
This is
the grease to lubricate the moving parts of the combi itself. If grease and
oil
or seater comes out the back of the combi then think about servicing the
combi.
(kit available with diagrams and instructions £38). The combi should be no
more
than two thirds full of grease otherwise you may blow the lip seal in the
combi.
The prop should be fully filled iwth waterproof grease. This should be checked
every year. Full instructiuons are avialble on the VAGB/USA Vega CDROM in
Technical Notes.
I hope this helps a littke bit.
regards
Steve Birch
At 19:13 23/06/03 -0400, you wrote:
Oct 31, 2019
3
Thank you Aksel,
Now I get curious. Are you Aksel Jensen Vega #2148 ??????????
Best wishes
Erik B. SimonsenAt 23:00 23-06-03 +0200, you wrote:
Oct 30, 2019
1,459
Anyone have success with those $65.00 moldable replacements for flax packing in an old fashioned stuffing box (stern gland)?
Nico WalshNicholas H. Walsh P.A.Admiralty and Maritime Law; Probate Litigation; Commercial LawPhone: (207) 772-2191Fax: (207 774-3940P.O. Box 7206120 Exchange St.Portland ME 04112This message is from a law firm, and may contain information that is privileged and confidential. If you suspect you are not the intended recipient, please delete the email and call us.
