Hi Tom, Yes, you can raise and lower the mast by yourself, with a special
Mast boot and tabernacle. I have made one for my boat and it works slick as
it uses the center and rear shroud lines to guide the mast up and down. The
mast must travel in a arc for two reasons first, the shroud lines are on a
different plane, and second you must clear the main cabin roof when it comes
down into a crutch on the rear of the boat. I will try to send a drawing of
it on this note.[Unable to display image]
