Doh! Using the grinder approach would have been much easier than taking the furniture apart. (Now why didn't I think of that!!) Oh well, if I had known about this method before starting, I probably wouldn't have used it, since I was undecided about replacing the thru-hulls. Now that I'm certain to replace the thru-hulls, I might use the grinder/cutting approach to remove the last valve under the sink.
I haven't gotten to the shopping stage for replacements. I was not aware that there might be a problem locating replacements of the correct size. Thanks for pointing this out. IMHO, you would especially want to thru bolt the smaller ones, even more than the larger ones, since they are on smaller thru-hulls and therefore weaker. During the removal of my old gate valves, the only one the broke for me was the engine cooling thru-hull which was one of the smaller ones. Other than finding a source for the correct size, I don't see any alternative but to install larger ones as replacements. Since the new valves will have twist handles instead of large knobs stuck out the side, space shouldn't be a problem. It is just getting the courage to take hole saw to the side of the hull.
What about material? Have you decided what to go with, bronze? stainless? marelon? other? I am giving serious consideration to marelon, but I haven't made a final decision yet.
Good luck with your project.
Chris
