Chris, Do you have a tide where the boat is? If so, ride the tide. Anchor
when it changes direction if the bottom is so fouled that you can't make
headway. The 6hp should do 4 knots if the bottom is clean, spend a bit of
time with a mask, fins and a wide putty knife as a scraper before you go.
Welcome to the cult. Walt, Lyric #120
P.S. if the boat doesn't have GOOD ground tackle before you go, invest in
it. It's the best and cheapest insurance you will ever have for the boat.
