Dear Morton,
I donot know whether I understood your messatge. Are
your suggesting to replace the Dynastart in your Vega.
That's very very expensive. Maybe you could repair the
old one, mine could not be replaired and the local mechanic divised something
else.
Hopefully I can explain this. As you know there is also
a separate dynamo on the Albin motor.
Well this dynoma can easily load two batteries, its
needs only a rectifier. In this way the problem was elegantly solved and the
dynastart continues its life as a starting engine.
Best regards,
Henk Jansen
Vega 1782 Le Cygne.
else.
Best regards,
Henk Jansen
Vega 1782 Le Cygne.
