Has anyone experienced the endless amusement of working on the drive head of their Raymarine Autohelm ST4000
? All models of the ST4000 are applicable. Raytheon is the latest iteration of Raymarine.
Usually I enjoy challenges such as this but with this obstacle, it's almost as if the manufacturer doesn't want to talk about the elephant in your grandparent's parlour.
The pachyderm I'm referring to is the Adjustment eccentric assembly shown as parts #12, 13, 14, & 15 in the below drawing, Figure #7 :
The service manual (attached below) spares no ink in describing how to disassemble a similar part #11, 10, 9, & 8, the Drive eccentric assembly, which a vision impaired man would be quite comfortable with. But that's not my problem. Te problem is with the Adjustment eccentric assembly (parts 12, 13, 14, & 15). All you get is "stuff 'er back together and be done with it" as shown on page 18 of the service manual. No mention of how to first take it apart.
I have tried pushing, pulling, pumping, and humping but nothing will separate these pieces. And I doubt it would separate them because of part #14 which is a lock nut. I have tried to remove the cap, part #15, but all that does is remove chips of plastic from the cap.
Any experience anyone can offer would be most appreciated and as a show of appreciation, I will mention you in my will. No money mind you, but I will mention you
Thanks as always.
PS. I have posted a revised drawing to show the difference between the two eccentric adjusters.
Thanks as always.
