Raymarine thru-hull
Jan 7, 2011
6,013
Oday 322 East Chicago, IN
My 1996 Hunter has a Raymarine ST-50 plus Tri-data, which I think used a Z092 speed /temp transducer (retractable).
I need the plastic thru-hull and nut (but not the actual paddle wheel assembly).
Anyone know if there is an Airmar replacement that will fit this transducer? I hate to replace the transducer because the housing is shot....
Thanks in advance,
Greg
Ted
Jan 26, 2005
1,280
Airmar makes most if not all thru hull transducers for Raymarine. You shouldn't have a problem finding a replacement. Contact Gemeco.com
Jan 7, 2011
6,013
Thanks for the help. I was able to find the right fitting (P120) and then found a new one on ebay, with the housing, nut and a blanking plug.
The thru-hull has now been replaced, and Obsession should be in the water soon! Been a long winter in Chicago...can't wait to get back on the water.
The help on this forum is really top notch.
Thanks again,
Greg
