Raymarine ST50 tridata replacement
Nov 29, 2017
2
Hunter 33.5 Lake Arthur Yacht Club
I need advice. I have a old Raymarine ST50 tridata that is not working. I found a Raymarine I50 that looks to be the same size & fit as old st50. Problem is Raymarine will not confirm if the current cables will plug in and work. This is on a 1994 Hunter 33.5 Any advice would be helpful. Thanks!
Jun 6, 2006
6,990
OK, welcome to Raymarine. ST=SeaTalk which all have round three tire twist on connectors
ST1=SeaTalk1, which all have crescent shaped three wire connectors. ST2=SeaTalk2 (I've never seen these) are 5 wire cables and I don't know what the connectors look like. Think you have ST or ST1
STng is SeaTalk next gen and is (almost) identical to NMEA 2000 (the connectors are different). STng can be converted to the old ST, ST1, and ST2 using (you guessed it) ST? to STng adapter plug.
The real question is what does the rest of your SeaTalk network look like? What device do you want to connect it to? The best way to understand this is to download the ST networking guide from the raymarine site. It has lots of pictures of the various things you can and cannot get away with.
