raymarine st 50 transducer
ISIS
Apr 27, 2011
18
ISIS 42'MKII Toronto NSW Australia
Does anyone know how to get the bearings out so they can be replaced
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Chances are you will end up having to get a new transducer. From what I can discover they are common to most Raymarine units andpossibly other brands. They are manuactured by Airmar. I had an ST 40 Bi data on the boat when purchased and I changed out to ST 60s The transducers that were packaged with the ST 60s were identical to those already in the boat. I installed the ST 60s on the pedestal and move the ST 40 to the nav station, linked them via seatalk and they all work. I still have the new transducers never installed.
ISIS
Apr 27, 2011
18
Hi,thank you for your reply. I need to change the bearings on both the wind & close hauled I have the transdusers on the bench but how do I get the bearings out do i have to 'pull' the little senders off the end of the shaft & if so what then ??The bearing closest to the vane looks like it should come out from its rear Your help is much appreciated
Regards Don Nott "ISIS''
ISIS
Apr 27, 2011
18
HI Thanks I now have the tech specs for the bearings from you all I need now is the removal method Many thanks I did'nt expect a reply at all the system of forums really works Don Nott "ISIS"
ISIS
Apr 27, 2011
18
Thanks Doug, I'll chase that up if I cant find a way to get the bearings out,I'm an old tech & still think items can be repaired Regards Don
Rick D
Jun 14, 2008
7,206
Wind speed bearings? If so, I may have a set I ordered but never installed. They are yours if you want and if I can find them. Let me know.
ISIS
Apr 27, 2011
18
Hi Rick Amazing, Thanks I would really appreciate it if you could post them to me let me know your address so I can send you something for costs at least .Just for info i just pulled the the bearings out from the front by pulling on the shaft.My address is
Don Nott
PO Box 219
Springwood
NSW 2777
Australia
Thanks heaps to you & everyone who gave me clues I hope I can do the same for some
one else who needs a hand. Regards Don Nott "ISIS"
Australia
