Raymarine Linear Drive Install - easy way??
Hunter 34 Herrington South, MD
https://photos.app.goo.gl/bwcqjmZ6CctdAJaw7
We upgraded our old Raymarine system with an Axiom 9 MFD. Unfortunately, the older autopilot was not completely compatible with the new Axiom, so we purchased the newer autopilot, again with the wheel drive unit. Unfortunately (again) the new wheel drive unit was not strong enough for our H34 (even though the old wheel drive unit worked great for decades). We were able to upgrade ($$$$) the new wheel drive unit to a linear drive that would handle a H34. To install the linear drive, you need to have a custom-made short arm to go around the tiller post. Unfortunately (again) that was both very expensive and on the H34 there was no place to attach the short arm on the post. I came up with a relatively inexpensive way to attach the linear drive to the tiller post drive wheel (??) (TPDW) the wheel that has the cables that actually move the tiller when you turn the ship's wheel.
Essentially, I cut two pieces of 1/4 aluminum and mounted them to the TPDW with bolts and lots and lots of washers to take up the space and keep both plates parallel with the TPDW. I then installed a 1/2 board in the rear lazarette as a base plate upon which to mount the linear drive below deck.
Install photos at https://photos.app.goo.gl/bwcqjmZ6CctdAJaw7
Article in HO Forum for H34 mods
So far the install has worked perfectly.
Other mods are at
5,602
Pearson 37 Lusby MD
Photos, please. :beer:
Certainly is a way to do the necessary structure. Hope it holds up. I think I would have tried a bushing instead of washers. Let us know how it holds up to the stresses of a seaway.
Appears to be a stronger setup than the EVO100 wheel pilot.
i agree that bushings would have been better, but we were able to ensure that the two aluminum plates were parallel with parts that could be obtained (by numerous trips to the hardware store near our marina) without trying to get bushing that were exactly right.
We had a wheel pilot with the new autopilot but kept getting reboots and statements that there was insufficient voltage. RM technical said that the new wheel pilot wasn't strong enough for our boat even though we had used the older version for decades. We've used this in heavy weather with great success. One of the major benefits of the new AP is the ability to follow/maintain the wind angle. My partner's wife and I aren't the real sailors and we both got tired of hearing her husband say "fall off a little Mike" "etc." "etc." Now we get to hear it once, set the AP and we maintain the same angle to the wind automatically :)
5,602
Pearson 37 Lusby MD
I bought one of the newer RM wheel pilot units when the old one that came with the boat bit the dust. I was completely underwhelmed by its performance, so went with the linear drive.
when we upgraded I went to the RM site and saw the "same " unit so we bought it, but later RM told me to read the text which had a weight limitation which our H34 exceeded so your 37 was probably too much for the wheel pilot also.
5,602
Pearson 37 Lusby MD
Yep, fine hairy edge of what the wheel pilot could (n't) handle!
colemj
Jul 13, 2004
1,185
What is the white board you used to mount the drive unit? If it is starboard or pvc board, I'd change that to something more dimensionally stable. Starboard and pvc can cold creep under load, and this will accelerate once the bolts become a bit loose in them. The drive arm mount experiences significant forces - more than most people think. Your choice of where and how to mount it is great for handling the forces, but the spacing boards could be an issue if they can deform.
Mark
  • Helpful
g
Mark
I believe we used starboard that we bolted in all four corners and used an adhesive all over. But your point is well taken, the shear torque on the bolts would eventually lead to the flat washers digging into the starboard. An aluminum plate instead of the washers would be the better solution. If we see problems I'll do an upgrade. Apparently my engineering mind went blank after the major install :)
  • Ha
