https://photos.app.goo.gl/bwcqjmZ6CctdAJaw7
We upgraded our old Raymarine system with an Axiom 9 MFD. Unfortunately, the older autopilot was not completely compatible with the new Axiom, so we purchased the newer autopilot, again with the wheel drive unit. Unfortunately (again) the new wheel drive unit was not strong enough for our H34 (even though the old wheel drive unit worked great for decades). We were able to upgrade ($$$$) the new wheel drive unit to a linear drive that would handle a H34. To install the linear drive, you need to have a custom-made short arm to go around the tiller post. Unfortunately (again) that was both very expensive and on the H34 there was no place to attach the short arm on the post. I came up with a relatively inexpensive way to attach the linear drive to the tiller post drive wheel (??) (TPDW) the wheel that has the cables that actually move the tiller when you turn the ship's wheel.
Essentially, I cut two pieces of 1/4 aluminum and mounted them to the TPDW with bolts and lots and lots of washers to take up the space and keep both plates parallel with the TPDW. I then installed a 1/2 board in the rear lazarette as a base plate upon which to mount the linear drive below deck.
Install photos at https://photos.app.goo.gl/bwcqjmZ6CctdAJaw7
Article in HO Forum for H34 mods
So far the install has worked perfectly.
Other mods are at
Other mods are at
