Raymarine Fluxgate Shuts Down
May 28, 2015
280
Catalina 385 Atlantic Highlands, NJ
My fluxgate compass works fine at power up each weekend but after about 2-4 hours the compass shuts down. The "no compass" alarm triggers as well as the "no heading" alarm. Once this happens the fluxgate won't restart unless its been off for a while (typically overnight or during the week). The batteries are fully charged and this occurs while at dockside. Any thoughts on what might cause this behavior?
Nov 8, 2010
11,386
It sounds like you might have a thermally intermittent component on your fluxgate compass PCB. You might be able to confirm that with some freeze-it spray, but that would only tell you what you already know; your compass is failing.
Jun 6, 2006
6,990
I agree with JackDaw, something is heating up. Check the easy stuff first, connections to the AP computer and any splices in the wire between the fluxgate and computer. If that all checks out then you are looking at replacing the fluxgate. Don't thing there is any way to crack the case and peek inside.
May 28, 2015
280
I should have mentioned that this same issue occurred with a second fluxgate ... I'm thinking it might be something in the DC circuit. Would a switch going bad create this type of symptom?
May 24, 2004
7,213
CC 30 South Florida
A small short in the wiring, a loose connection or like you suggest a failing switch might create the symptoms. Since the problem repeatedly defaults to the fluxgate compass I would start by tracing the wiring from it all the way back to the control unit. Check connectors. The chances of two fluxgate units failing in a similar fashion over a short period of time are not very good so if nothing is found in the wiring I would start to suspect the control unit. How old is the autopilot?
Jun 6, 2006
6,990
Agree with Benny, two failing in the same fashion is not likely.
the control computer does have to source lots of current to drive the AP motor so it makes sense that something is getting hot in the control computer and effecting the fluxgate circuit.
Again check the connections at the unit. Perhaps the heat is coming from the motor connectors and cleaning them up will keep things cool enough for the problem to go away.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Also what is ambient temp. Is computer in or near the engine room, in an unventilated compartment, etcetera.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Normal electronic treubleshooting procedures
If you can make it fail, be happy, you're almost there. While in the failed condition, measure power and grounds with a voltmeter. If you are unable to see a fault and the system is still inoperative, you have eliminated that as a source of the problem. If it is a power or ground problem, chase it. Be sure to be on the lookout for corrosion. Corrosion can cause low voltage or outright open circuits when they heat up due to resistance of the corroded connection. Sometimes it's just easier to replace connectors because you can't see the corrosion.
If it's on a circuit board, I absolutely agree that freeze spray could help locate a faulty component, but it isn't really just telling you to throw it away. Individual components are usually really cheap. Just replace the bad resistor, capacitor, transistor, or whatever. I realize this may be dough for a novice, but it isn't impossible.
In today’s world, there is no excuse for anyone to not have a functional multimeter.
One example
http://www.harborfreight.com/7-function-digital-multimeter-90899.html
Or if you are also interested in chasing AC problems
http://www.harborfreight.com/clamp-on-digital-multimeter-95683.html
No connection with the company, it’s just cheap.
Ken
Feb 6, 1998
11,759
There really is not a ton to go wrong with a Fluxgate and they usually either work or don't. In my experience the problem is most often in the course computer. You can test the fluxgate easily. The CC would need to go back to Raymarine..
Set DVM to:
  • 200 ohm scale
  • Disconnect the transducer from course computer
  • Take measurements (a +/- 2Ω reading is okay)
Red to Green = 4Ω
Red to Yellow = 4Ω
Green to Yellow = 8Ω
Screen to Blue = 8Ω
Any other combination of wires = Open Circuit
May 28, 2015
280
Update:
About a five weeks ago the autopilot began reporting no compass consistently. Tested old compass using the Ohm test from Maine Sail. All readings checked out. Tested red and bare for volts ... 2.4 volts at the smart pilot. Bought new Fluxgate ... Same problem.
Checked fuses on smart pilot board ... All good.
Checked inbound voltage on smart pilot ... 13.2 volts.
Checked voltage on rudder reference terminal ... 4.1 volts.
Should the smart pilot reduce voltage to the Fluxgate and rudder reference to this degree?
If not, is there anything else I can check?
Seems like I should probably ship the board to Raymarine.
May 28, 2015
280
I meant to close this out with the final resolution. The computer and fluxgate were shipped to Raymarine and both worked fine on the bench. Traced the issue further to a run of fluxgate wire that had failed (it had two splices between the helm and the bilge). Once the failed section of fluxgate wire was bypassed, the fluxgate works fine.
