- Oct 22, 2014
- 23,389
I'll bookmark it for LynnHolds a straighter line then my wife.... I did not say that....
So I’m about to install mine. Same boat as u. I noticed u put nearly everything compactly together. I assume the ACU is directly battery mounted and not thru the breaker box? Some part of me feels I should be putting it thru there. Maybe to make sure it’s not drawing battery current. How is this setup working for u? Does it work well? Any problems with making too many adjustments? Have u per chance installed a rudder reference unit since this post?Finally pictures of the installation. The head unit is not in the best place, but that is where the old ST-4000 head unit was, so easy replacement. Later I'll get it to the wheel.
...and I know about the mildew. You wouldn't believe it, but I spent several hours cleaning the lockers before installing the system. At the time my local West Marine was out of the mildew remover spray, but I have plenty now.
My entire autopilot an EV100, and all my electronics run through the dc panel. That would be the entire N2K network, the VHF, the chart plotter and the ACU. That way I can turn off the entire electronics package, or turn off individual parts at the instrument. No way I hook up my ACU directly to a battery!I assume the ACU is directly battery mounted and not thru the breaker box? Some part of me feels I should be putting it thru there. Maybe to make sure it
Not the way to do it.I assume the ACU is directly battery mounted
It was too difficult to get wires back to the chart table panel, so I added a fuse box on the aft bulkhead of the locker (see photo). The system required two different fuse sizes, maybe one for the control unit and one for the motor. Relatively easy to turn on and off since the locker is right next to the wheel.So I’m about to install mine. Same boat as u. I noticed u put nearly everything compactly together. I assume the ACU is directly battery mounted and not thru the breaker box? Some part of me feels I should be putting it thru there. Maybe to make sure it’s not drawing battery current. How is this setup working for u? Does it work well? Any problems with making too many adjustments? Have u per chance installed a rudder reference unit since this post?
