Just thought I'd lob this out to the guys in case anyone had something similar. I e-mailed Raymarine already and went through their FAQ's.I have an RC 70 chartplotter which I use in chartplotter mode only (it will also serve as a radar display). The antenna is a Raystar 120 WAAS with Seatalk link. The seatalk is chained through a bus. Anyhow, I get some "NO FIX" messages from time to time. When I query the sat status screen, it is blank.. no sat info. When I select the reboot soft key, nothing happens. If I power the unit off for maybe ten minutes, I usually get a full signal.I installed a new GPS antenna about two years ago after a similar problem, but more aggravated.. Thanks to John Richards, I found out about an antenna recall for a certain series of production. Raymarine replaced it at no cost and I had no problem for about a year. Now, I seem to be having it again.Any thoughts?Rick D.
