RayMarine / C- Map compatibility
49
Beneteau 361 Charleston
I have a Raytheon RC520 chartplotter running software v6.05. I had a 112LP seatalk GPS which recently failed and I replaced it with a seatalk 120. With the original configuration I was succesfully using a C-Map NT+ card, but after installing the 120, the chartplotter cannot get past it's boot routine when the NT+ card is installed. If I take the NT+ card out of the chartplotter the plotter comes up and correctly reports gps position. Any ideas that don't include a $1,000 equipmant upgrade
Mar 20, 2004
1,753
contact raymarine tech support
you may not need a $1000 upgrade, but you may need a software upgrade to make the nt+ /520/120 combo work correctly
Jun 4, 2004
49
Raymarine / C- Map
One answer form Raymarine tech support sais I have to send the unit in for an upgrade ($800) another gave me a part # for a software upgrade. I've sent an email to get clarification.
Rick D
Jun 14, 2008
7,204
Stan: Report Back What The Deal Is...
...I'd like to know if/when I also do this. Rick D.
Mar 20, 2004
1,753
raymarine software upgrades
It might be the same situation as I've got with my RL70s: the upgrade software is available on a cartridge you can simply put in the system and load, or you can send the box back for a new board-the $800 upgrade may include more than the needed software (on the rl-70 it gets you the "plus" features)
Jun 4, 2004
49
Software Upgrade
The written answer from Raymarine is that the software upgrade will not address the incompatiblity with NT+. My 5 year old system is HSB and the software allows HSB to communicate over Seatalk with HSB2. So here is the REAL rub. I can upgrade my old monochrome display for $800. If I choose instead to buy the new "C" or "E'" series then I get to throw away my C-Map cards because RayMarine has moved to Navionics. I feel that I'm in a Catch-22 never never land. The rest of my system is SeaTalk, ie autopilot, etc so to keep full functionality I need to stay with RayMarine and spend money for a new chartplotter and new electronic charts.
Mar 20, 2004
1,753
one last thing to try
That's weird! Stan, it may be stupid, but have you tried booting the system without the nt+ card, and then installing the card?
Jun 4, 2004
49
Tried It
Yes, I shut everything down and booted the system without the NT+ card. The Chartplotter and GPS work perfectly. The minute I put the card in and try to change the range the system freezes. I may have a solution. I can still get NT formated cards from C-Map. The charts are uptodate but have less information than the new NT+ which is no problem.
