We are thinking about adding AIS to our boat this year. We have a RM C120W MFD on board so thinking the AIS350 would be a simple plug and play solution. I'm interested if anyone else is using this unit and how you like it, good sensitivity ? any other issues etc.
thanks, Bob
I also have a RM C120 and elected to go with the Standard Horizon GX2200 (DSC+AIS+GPS built in). The reasons are good IMHO.
Since it already has GPS built in, I don't need a feed from the chart plotter for emergency DSC. It also has AIS built in and all I have to do is feed the NMEA output to the RM input and it displays quite well. It also has it's *OWN* AIS map display built in to it functions as a nice backup for both GPS and AIS. It displays SOG and other useful information.
You can also get the remote microphone for the GX2200 which also displays the AIS targets and GPS position.
If you need to contact a remote AIS vessel, you just press the call button.
There is no separate AIS "box" that requires a separate fuse/wiring/mounting solution and doesn't require yet ANOTHER "box" for splitting/sharing the VHF antenna. The VHF splitter box alone is $150+ bucks. Unless you are terribly attached to your old VHF radio, dump it for a GX2200.
Highly recommended. [grin]
