Raw Water Pump for Boat's Refrigeration
Sep 9, 2013
5
Hunter 380 Marina Del Rey, CA
I have a 2001 Hunter 380 with raw water refrigeration. The pump has gone out and needs replacing. Looking at the parts for Hunter 380, they recommend a pump that runs about $450 - 500. I have also found other pumps at Westmarine and other marine stores for less, but don't know what the compressor needs for water, i.e. 300 GPH? I currently have a johnson pump that is rated at 750 gph, but have had to replace it several times, as it is actually designed for bait tanks. The pump has a 3 year warranty and i've been replacing her about every 3 months and figure i just need to get a better, heavy duty pump designed for this function.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
When mine went bad my refrigeration mechanic said to replace my cheap pump with a good one. We installed a March Pump 893-09. These cost around $300.
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
You should contact your Refrigeration Company for raw water flow and temperature requirements.
I am wondering why you had to replace the pump so often. What was the cause of past failures?
Impeller, seal, motor, debris, pump housing, corrosion....??
Jim...
PS: With the above info, many can help guide you.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
more info on the pump would be helpful as in what type..... brand....12v dc or 120v ac and a pic would be really nice ...from reading your post it sounds like you are using a bilge pump to cool the refer
KD3PC
Sep 25, 2008
1,069
boatless rainbow Callao, VA
2nd vote for March pumps, they seem to work better and last longer than the others, at twice the price.
