raw water intake thruhull on C27
ron
The area where the raw intake pipe stub passesses through the hull has a small crack that leaks. Is this a matter of cutting out the old pipe stub,crack and replacing it with a new strainer and real seacock? Should the new one be epoxied in place or does it just get tightened down? I know this is a commom problem but I cannot find referrence to this repair in the archives. Thanks !!
G
Garry @ S/V TASHTEGO
Thru hull
Ron, a leak at the pipe stub is a dangerous problem which should be delt with right away. I assume that the crack is inside the hull on the goop they plastered around the pipe stub. If its in the hull itself you have an even bigger problem. I'm repairing / replaceing all my gate valves with bronze thru hulls and sea cocks. I've started on the head inlet. When I tried to unscrew the gate valve the whole pipe stub came out. When it warms up a little I'll grind off the goop on the inside of the hull then cut a hole through from the uotside using a 1 1/8 inch hole saw. put the thru hull in with a generous dollop of 4200 an screw the thru hull nut down tight on the inside. Then make a backing block big enough to take the flange of the Seacock, drill a pilot hole through the center of the block and rout a hollow to fit over the nut on . I have a circle cutting rig for my router that did the job. Use a sander to shape the bottom of the block to the curve of the hull then give the block two coats of penetrating epoxy. Glue it down with a layer of 4200 and screw on the seacock. If you use a good thick coat of 4200 you can probably get the handle of the seacock in the right position. Leave about an eighth of a turn, then snug it down when the 4200 is solid (3-5 days). Use 4200 instead of 5200 or you will not be able to take it apart again. The seacock flange will have bolt holes. Its up to you whether or not to put bolts (and bolt holes) in. Remember to put the nuts on the inside and countersink for the heads on the outside. If you are doing the engine inlet you should use a strainer type thru hull and you will have to put the bolts in. Good luck. When I finish mine I'll do a photo collection and post it for others to see. Cheers, Garry
L
LaDonna Bubak - Catalina Owners
Thanks Garry!
Luckily the gate valve in my galley appears to be ok and it's rarely used so it's kept closed but that doesn't stop me from checking it frequently and keeping my fingers crossed! My head has a "real seacock" that just a few years old. But when the time comes to replace the galley one, I'll be using Garry's instructions! LaDonna
