C
Carl Nencetti
I was told by the surveyor when I bought Mambo last month that the raw water hose from the seacock to the raw water strainer has some small cuts in it and should be replaced. Looks fairly easy (4 hose clamps and a 2 foot hose). The surveyor mentioned that the hose was nothing special and could be replaced with something from a hardware store. After thinking about removing the hose I was wondering if I should worry about water draining from the raw water system. I expect some water to drain from the hose, but will I have much more coming out of the cooling jacket? I am also concerned that I will introduce air into this system that I won't know how to bleed. Any thoughts about whether these will be problems I'll encounter or will it be simply removing the old hose, catch some water as it drains from the hose and replace it with a new hose?Thanks,Carl
