We own an 88 Cat 30 that we have completely reconditioned over the past two years; however, we are still chasing one last annoying issue. When under power we hear a loud rattling sound at various RPMs. The sound is a clacking sound, almost like slapping two boards together. It is easily audible and occurs only when in gear. It does not occur at all rpms and is avoidable if I stay out of the rpm ranges where it occurs. Otherwise the boat runs well under power, no issues, vibrations etc.I use a very good local mechanic and we have checked the motor mounts, cutlass bearing, prop, shaft alignment, even put a diver under the boat while it was running in gear tied in the slip. The diver didn't see any excessive vibration in the prop, prop shaft etc.We’re running out of places to look and things to check. Any ideas or experience with this problem would be greatly appreciated.
