Raritan Sani/Flex
11,769
Peggy,
I'd appreciate your thoughts on the Raritan Saniflex butyl hose? I am about to do another re-plumb and usually use Trident 101 but it is anything but flexible... Is the Saniflex as good? How is it priced and who stocks it?
Thoughts appreciated!!
Feb 6, 1998
11,769
Bump.... And yes I did a search but could not find your opinion of this hose compared to Trident 101...
Feb 10, 2004
204
Hunter 426 Rock Hall, MD
Mainsail; I just asked the same question from Peggie 2 days ago. Her response was that the new Raritan SaniFlex hasn't been around long enough to establish any track record. For now stick with Trident 101 or 102.
Feb 6, 1998
11,769
Thanks!
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
I agree with that in principle, except the Saniflex is WAY easier to work with, certainly in a league by itself. In some cases a shorter life might even be acceptable. It is that much easier. Of course, the truth is we don't know.
When I needed to re-plumb my head, as part of a Practical Sailor test, I used the heavier lines for the sections that were most permeation prone (head to tank and tank to pump-out), but used the Saniflex on a tortuous run where the stiffer hose got in the way (over-board pump-out).
http://sail-delmarva.blogspot.com/2011/09/easy-button.html
My personal bottom line is that I would stick with Trident 102 or Poly-X and save the Saniflex for lesser risk tight spots for now. You couldn't give me a spool of Odorsafe Plus--sure, I can make it fit and I believe it will last, but I don't want to work with it.
No one said you had to use all one hose type! For example, the vent won't be 102, since you'll have trouble finding anything but 1 1/2-inch. I think Sainiflex has a place in the tool box. How big a place, we don't know.
