Raritan PHC dimensions
1,816
Oday 31 Redondo Beach
I can't find the dimension for the depth, including pump handle, of the PHC.
The PH II is 17" without the handle and 19 1/2 with the handle. The only depth dimension I can find for the PHC is 16 3/4. I assume that is without the handle. Does anybody know the overall depth with the handle?
Allso, I would need the discharge exiting the to the side. The only pictures I see have the discharge exiting down. Is that adjustable?
The PHC isn't even on the Raritan web site.
Thanks for the help.
Bob V
Mar 13, 2008
235
Catalina 42mkII Lagoon Point
Here is a photo that may help. I only have about 1/8th inch clearance to the back bulkhead so the dimension reads 16 7/8th to the front of the bowl. As you can see the handle does not stick past the rim.
The discharge is easily adjustable to swivel in any direction you choose.
The head is a major improvement over the Jabsco that came with the boat.
Bob V
Mar 13, 2008
235
one more photo
as you can see the handle extend 15 inches from the bulkhead.
Bob V
Mar 13, 2008
235
Not the same toilet, Steve
The compact II and the PHC are different. The PHC uses the same pump as the PHII (full size). It is essentially the same as the PHII except for a shorter handle and a base that does not require a trim skirt. It has a smaller footprint and thanks to the short handle it does not extend as far out from the bulkhead. Compare my photos to the drawings and that will be clear.
I think when I made that same mistake, Peggy told me that the PHC was the one to get and after getting to know it I am very impressed. It is a very well built product and works great.
Jun 11, 2004
1,816
Thanks
Bob thanks a bunch. That is exactly what I need to see. Did you take those pictures just for me? They're perfect.
Steve thanks for trying. I appreciate it.
Richard
Dec 2, 1997
8,975
- - LIttle Rock
PHC dimensions
The PHC uses the same pump as the PHII, but on the compact base to fit in the same space as the Compact (CPII)...and the only bowl the PHC can use is the smaller "standard" bowl...so the dimensions for th CP II are actually all you need to know if the PHC will fiit. The pump handle is the only real variable...it's about 4" shorter than the handle for the PH II.
If that doesn't work for you, call Vic Willman at Raritan--800-352-5630 x 6 for the exact dimensions.
I've been trying to get Raritan to put the PHC on their website for nearly two years...I'll push 'em again.
Bob V
Mar 13, 2008
235
You're welcome Rich
Yes it was just for you. When I read your post, I was so touched by your need that I got up out of my chair and walked all the way to my boat (40 paces) and shot those photos. It was raining too.
Well, gotta run Lassie just told me that Mrs Johnson is stuck in that well again. I'm off.
May 31, 2004
197
Catalina 36 MK II Havre de Grace, MD
Re: You're welcome Rich
Bob V to the rescue, what a guy!!!!
