This is a tough one but just maybe someone has the answer. My PH 11, post '92, will discharge water from the bowl but will not allow water from the seacock in. Have verified water coming through seacock thru inlet hose to flush/dry chamber. Have verified flush/dry selector is in proper position with a 1/4 turn. Chamber fills with seawater. Ball and spring replaced and properly oriented. Have completely disassembled pump and no obstructions. All seals and gaskets replaced. Isolated vented loop system to check for issues there. No problems. Removed outlet hose from pump and verified no water going thru pump. Any ideas?
