Raritan LBA dimensions?
RichH
Feb 14, 2005
4,773
Kindly advise where I can find/examine the physical dimensions of the:
"Raritan LBA matches your existing bowl with the pump/plumbing of a PHII or PHC". ... Either on this site or on the Raritan website, etc.
Ditto where I can find a listing of the competitive bowl, etc. flange, etc. connections. I have an old ITT Jabsco unit that I want to 'covert' with the LBA.
Thanks
This is a GREAT idea.
regards
RichH
Dec 2, 1997
9,010
- - LIttle Rock
Dimensions for PHIILBA and PHCLBA
Are the same as the dimensions for the complete toilet when the bowl, seat and lid are installed.
Rich, if your old Jabsco bowl has the typical 4 bolt mounting patttern--99.999% of toilets do--it will fit the PHII and PHC.
You do need to be aware, though, that only the smaller "standard" size bowls will the PHCLBA. That has nothing to do with mounting...the larger bowl is too wide at the top to fit next to the pump when mounted on the compact base. Both the standard bowl and the larger household bowl fit the full size PHIILBA.
RichH
Feb 14, 2005
4,773
Thanks Peggy
The reason for the dimensions is that my boat was custom built and the damn head where the toilet is located was 'closely' built around the Jabsco Dimensions ....
Is that pump handle easily removable on the LBA?
Dec 2, 1997
9,010
- - LIttle Rock
Yep. But since it stick out of the front of the pump, it shouldn't cause you any space problems. There's no difference between the pump and pump handle with the LBA and the pump with the complete toilet..and it doesn't matter whether then handle on either one is left up or down...the pump can be on either side of the bowl in both versions. The PHC handle is shorter than that PHII handle, btw.
