Danny Hales
The compression post ( supporting Mast ) is corroded at attachment located at keel.I want to replace the corroded compression post without de-masting . Is this possibable ? My idea is to temporary replace existing compression post with a four x four tember from keel to the top of compression post ( inside fiberglass top )then remove existing compression post and install replacement. My situation is that I do not have any details on how the mast is attached to the compression post.1. Can I replace compression post without de-masting ? 2.If yes, How ?Thanks fellow wind sailors.
