launching
I have a 240 that I tow behind a Chrysler Town And Country. I launch it by myself. The extend tongue on the trailer helps out a lot and depending on the ramp, whether or not I put the mast up before or after I launch. Some ramps are either too crowded so I'll put it up later. Or if the trees have not been trimmed, I'll put it later.I tie a 50 foot nylon line to the bow cleat and loop it on the trailer. Push the boat off, tie the boat to a dock or pull it up on the sand. Go park the car and then go sailing.With 2 people it should should be a cinch to launch and retreive, even a 260. If your boat is a water-ballasted one, leave the valve closed until you get it in the water and off the trailer. Otherwise you have to be superman to get off the trailer.
