Raising the Mast on a 23
Tim
I want to be able to raise the mast regularly and with one person on my 1986 Hunter23. I plan to trailer it back and forth and to different lakes. I'm looking for a good system to buy. I have been experimenting with my homemade ideas, and not happy with the results. Anyone know of any good products that can be bought and set up quickly? Tim tbrouter@gawab.com
Oct 3, 2006
1,039
Hunter 29.5 Delaware city
mast
I don't know of too many ready-made mast raising systems for the 23. what you really need to make are a rolling rear mast crutch and solid or wire rope baby stays, with an attachment point in line with the rear pivot for the mast step. These 2 items are a must have. Then, you need the lifting power. One good place to start is the mast crutch - if you use a small winch, and can winch the crutch to make the mast stand up to about 30 degrees, You can really get away with having a 4:1 tackle attached to the jib halyard and simply pull it up. Otherwise, if you are starting from near horiztonal, you need a pole extending from the foot of the mast up about 6 feet. This pole also needs to be fixed so it CANNOT TURN SIDE TO SIDE. I do it myself with a rolling crutch and baby stays. I then hook the mainsheet to the bow, one end to the jib halyard and one end around a winch. I lift the mast from the back of the boat, take up the slack in the mainsheet, then start winching and up she goes.
Norse
Apr 9, 2008
4
Hunter 30_74-83 Ithaca, Ny
Side sway
I used to have this boat and found that the side sway is the biggest problem. I found (do a search) for a system made of conduit and a loose collar. I also made a graduated rear crutch so I could get it off dead level to start, and then just tied a long line to the forestay, walked around the front of my car and pulled it up. Norse.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Here's a few links that may be helpful
http://www.precisionowners.com/mastup.htm http://www.stewartfam.net/arlyn/mrs.html http://www.hereintown.net/~jsiehler/Stepping/Stepping.html http://www.macgregorsailboats.com/mast_raising.html
